Servomotor standstill voltages
I don't think so. In order to obtain "locked" position every phase should have different value. Certainly there are 3 positions where there is voltage only between two phases. Also I expect that when drive needs to lock positions on servo driver's outputs should be DC voltage.
I understand. Thank you for your answer.
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
237
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
446
Can we open a servomotor body, then reassemble it again without issues ? Because the customs at the airport want to see the inside of the motor ...
860
Do you know a supplier for the following item? Similar parts and other brands are acceptable. cooling fan for servomotor mounting Rexroth...
1,364
Kindly, we are using ip65 servomotors on diaper and tissue machines. But we are considering the ip64 servomotors for new projects. Has anyone...
1,013
