set a real time clock on s7 1200
wr_sys_rtc or something like that is a command to write system time. beside that when you're online there's function set time (take time from PG, or write you're own.
just to mention there's option in system properties to set timezone and DST
thank you chauvinhloi
its very helpful video
my question is: with that functions could I turn on a motor for specific date and time and how to??
best regards
If you read your system time to a DTL variable you use this to compare to your desired time.
You can use for example
DTL.Month=1 AND DTL.DAY=3 AND DTL.HOUR=20
To start the motor January 3rd at 20:00
Does anyone know how to set the real time clock in the Schneider m251? Or point me to the help file?
1,881
can anyone help me about how to use Real-Time Clock to run pump at certain time everyday
4,204
Hi, I am a beginner in RSlogix5000.:cool: (Version28.00 - Professional edition) I have to preset the tag's in the array(Real[45,60]) with...
2,353
I have a Siemens TP177B HMI & S7-315 PLC unit where the machine operator has to change some timer presets. The presets will be in the 9.999 REAL...
1,707
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
