Setting up S7 CP 343 - 1 to transer to S5
Just to make it harder, I'm working with German COM 143 software. If any one knows how to change this to English with S5 for windows that would be amazing.
In Netpro the connection established was no, but i've just tried to do a send from the S7 without the receive, whilst changing the S5 to only receive. The connection looked ok in Netpro, but nothing coming through and the lights on the LAN adaptor go off every few seconds.
What does Active Connection Established in the Netpro? You will see I have it ticked on the 2nd screen shot from the top. Does this mean the S7 becomes the Active station i.e. not the passive station?
I've managed to get the error bit to go to zero on the S7 block fc40. I believe I have a connection to the cp 143 card. I'd really like to know what the A-NR number is suppose to be for the incoming block set on the COM 143 software. There is an obvious A-NR number for the S5 blocks, but nothing for the S7. At the moment I have both the send and receive set to 1. I did realise yesterday I was using the wrong blocks for the S5. I have a CPU 115 and was using blocks for the other PLC types. Still no data though.
As you can see below, my connection is established, but no messages are being sent. I'm stuck.
on S5 side you have to call at least the RECEIVE-ALL block if you want to receive data, and SEND-ALL if you want to send data.
Use the parameter ANR which is shown in the NCM config tool.
Hi, thanks for your advise. I am calling in OB1 Send and Receive in the S5.
I'm not sure where the parameters you mention in the NCM for the A-NR is?
Hi I've bought a CP343-1 Lean ethernet card to connect my PLC to a PC running Citect. I've just spend all day trying to get the PC to talk to...
35
51,237
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
845
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
