SEW drive to Siemens PLC communication
nilpanch
Jun 2008
Gujarat
Dear all,
In our application SEW (MovidriveB) drive is used to determine the position of conveyer with the use of encoder through compiler program.
There are only two positions defined for the conveyor with physical confirmation devices and of course using encoder. These are ‘up’ and ‘down’ positions.
Now due to frequent slippage of mechanical devices, we need to change the encoder position values in drive compiler program & Siemens 315-2DP PLC program frequently.
We want to edit these two position values through only PLC program. This will eliminate to enter the values using the Drive key pad and reduce the repair time.
For this purpose, I need your help.
How do I write values in H10 & H11 through PLC via profibus?
I request you to do the needful.
If you need any information please revert back.
Hi everyone! I'm just installing a SEW MOVIDRIVE B to be controled by a Siemens S7 300 using an ethernet (profinet) network. The hole network is...
12,095
I'm trying to find out how to control a Sew Movidive using a Siemens S7-200 and the Profibus DP module (EM 277)... Any help? I've looked at the...
3,592
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
229
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
143
What does the 24V operation of sew inverter mean? I can't make the inverter starting the motor
509
