CLanford
Hi all,
I just had a SEW Movidrive VFD go out in my plant. Upon reinstallation and reconfiguring, I'm finding that some of the drive parameters are not taking in the new unit when I download the parameter and configuration data from MotionStudio.
The drive is a MDX61B0110-5A3, using the DFE33B ethernet card and the DHE11-B card. The VFD is controlling a servo motor and using IPOS technology to control the position of a large gantry. The VFD is communicating with a ControlLogix L61 via ethernet control words. So the VFD is set up in Logix as a generic ethernet module configured the way SEW requires.
I kept having a fieldbus timeout on the VFD which I determined was either a failing control module or DFE card, so I replaced both. Upon replacement and reconfiguring of the unit, I'm not getting any of the control data from the VFD anymore in Logix. The ethernet module is communicating in Logix, and I can talk to the VFD via MotionStudio with no problem. Doing a parameter comparison led to the object 078 and 079 being different. This is the "technology object" which is associated with IPOS.
The current module is set to "Standard" technology and I need to change it to "Technology" setting, however I do not see a way to do this other than what appears to be a special product key you get from SEW to activate this.
I've done several SEW identical MDX61B replacements in the same facility, but this one is really giving me a run for my money.
Does anyone have any suggestions, or know of any Technology activation keys that SEW uses that I can try?
Thanks!
Thanks!
