SEW Movidrive MDX61B parameter 819
Timer
Aug 2017
Germany
26
Hello, guys.
Can somebody help me with Movidrive parameter 819 "Fieldbus timeout interval"?
I need to increase it, but the manual said that it will be overwritten with the next PROFINET startup.
So how can I change it? I think it depends on PROFINET settings in TIA Portal, but I'm not sure which exactly. Should I change IO cycle update time from automatic to manual?
drives are Movidrive MDX61B with Either/IP interface cards with Controllogix talking to the drives. The DFE33B shows examples using the Generic...
3,578
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
134
What does the 24V operation of sew inverter mean? I can't make the inverter starting the motor
483
Hello, I'm having trouble with our SEW Movidrive "MDX61B0075-2A3-4-0T" error code F14 and I want to go through the program using MOVITOOL...
1,386
Hi everybody, In my project , I want to implement a positioning control of a Servo motor and drive from SEW manufacturer. My PLC is S7-1511-1PN...
2,068
