Engineer_MG
Ok. So, I see where your confusion is. I am editing my response because I understood what you are trying to do and what is happening.
The qualifier is more of an attribute of the action itself , how it's explained in the help files sounds more like "qualifying" a step but it's not.
So, you are trying to enable the step 147 only if the boolean LoPro_moveFlag1 is TRUE. But how this works is different, when the step becomes active the "S0" is setting the boolean LoPro_moveFlag1 to TRUE . This boolean will remain TRUE even if the associated step becomes inactive.
Did I understand you right ? If yes, then you will have to rework your code to incorporate your logic .
