Shared DB in RSLogix5000
mikas_m
Feb 2007
ck
154
Hello,
is it possible to create a data block, something like shared datablock in Siemens STEP 7, in the RS Logix5000 PLC project?
I would like to group different information (variables of different data types) in one datablock.
Thanks,
Mikas
Hi cardosocea and thank you for the reply.
I was looking for a convenient way to group a number of variables of a different types (bools, INT and REALs). In Siemens TIA/STEP7 DB is a really good way to do so.
So, the best approach would be to create a separate UDT in RSLogix i.e. a new variable that will consists of all these variables inside it.
I will investigate this possibility and how to do that.
Thank you.
Hello all. Is it possible to create a shared folder between my laptop and my PV+ 7- standard......2711P-T10C21D8S Series D? What I would like to...
435
Hi All, i'm upgrading a [3x] GE 30-90 system that extensively uses %G Global Genius Tags via Genius bus. This is changing to RX3i (CPE310)...
569
Hello CODESYS experts, once again I need help. Trying to setup a PROFINET device which supports shared device function, has four (4) IO modules (2...
884
I'm working on a project using a few kinetix 5500 drives, and I can't seem to get a straight answer from co-workers on power setup. I know you...
1,720
Greetings all, Wondering if produced consumed tags can be setup on a micro800 PLC? I'm trying to link 6 PLC's together so they have a few shared...
2,209
