CODESYS PROFINET IO Controller, shared device config
AlfredoQuintero
Feb 2015
Yokohama
1,551
Hello CODESYS experts, once again I need help.
Trying to setup a PROFINET device which supports shared device function, has four (4) IO modules (2 inputs and 2 outputs).
Want to have two of the modules communicate with S7-1200 and the other two with CODESYS. TIA portal clearly lets one choose which modules to configure. The problem is CODESYS does not give me the same option. Or maybe there is an option and I can't see it for some reason.
How do I indicate to CODESYS the two modules I want it to communicate with, and the two which it should free for the other controller. :confused:
As usual, thanks for any hints.
I try to show what I am attempting with the screenshot below:
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,880
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
201
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
294
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
154
