Shift register assistance (Modicon)
Bob Bass
May 2003
Working with a AutomationDirect plc and need to simulate the application prior to plc installation. Since they do no have a simulation utility (or at least I don't), have duplicated the program in Modicon's Concept (for which I do have a simulation utility). BUT... I have questions on how a shift register works in Concept.
In the AutomationDirect plc, the shift register works good (using addresses C100 thru C1777). How does the shift register know where the addresses are, or what they are in Concept ? Do I have to allocate an address range ?
Any help is most appreciated. I am attempting to wrap the program up today for delivery to the customer on Monday morning.
Bob Bass
Concept Shift Register
What command are you using, BROT, SHxx, ROxx, FIFO, or LIFO? How many bits are you trying to shift at one time? Over how many total?
To create data sources you need to define them as located variables, 4xxxx for 16 bit words and 0xxxx for single bits. If you are using single bits, you need to be sure they begin on word boundaries (i.e. 0x1->0x16, 0x17->0x32, 0x33->0x48). A group of sequential data types can be defined as an array, such as boolarr32 for 32 consecutive bits.
Hi Jim,
Thanks for the reply. What I was attempting to recreate the periodic shifting of 1024 bits and getting a bit based on a time constant. Was finally sucessful in doing it using SET_BIT, SHL_WORD, and a few GET_BIT function blocks. Although it was only 16 bits long, the process worked. Needed this data stream in the proof of concept for a larger process.
Today I commissioned the unit and all went well. Thankfully <g>
Thanks again for your reply.
Bob Bass
Suprising how much one does not retain after being away it for a couple of years.
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,148
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
686
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,063
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,669
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,605
