shift register (toshiba to gx developer) upgrading PLC
thacks
May 2007
england
Hi
Can some-one help me i'm now going to fit a new FX3N(c) PLC to replace a old tosiba PLC but i'm having a few problem.
In the old program there is a shift register which looks something like this
x1 (data) single input pulse
x2 (shift) single encoder pulse ( one pulse per rev of drive shaft)
x3 (reset) resets when shift reaches 17
How this works X1 pulse then the encoder shift 1 every rev till it reaches 17 then reset and also trigger x1 to shift 1 again. this is being used to scan faults conditions.
Any code would be great
Cheers
Chris
There are bit & word shift registers in Mitsi but as I don't have my pc with GXDev with me I cannot off hand remember, however if you add a function coil [ ] not () to a rung then on the popup press help button (on the popup)it will give you a list of instructions although these are not documented very well you might be able to find what you are looking for alternatively look on the mitsi website as there are manuals there
the link is
http://www.mitsubishi-automation.co.uk/
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,150
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
689
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,068
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,677
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,625
