shift register trap error
nmk
Dec 2002
38
I used a one shot input signal to trigger a shift register,and i am using two counters and two internal relays to trap the error,if it happen to shift more than once per cyle or did not shift at all.is there another neat way to capture these two problems.I have an omron plc. Thank you
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,184
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
704
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,078
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,731
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,721
