Shift Registo
mbinzain
May 2005
now in sudan
HI TO ALL
I WANT TO CONNECT DIGTAL ENCODER TO DIGTAL INPUT MODULE S7-300 TO CONTROL THE FOLLOWING:
as shown in the attached file i want to make program that is control the coneyor motor with 2 photot cell and one encoder the motor is running and pull the product when it pass to the photo cells the 2 sensor gives signal for good size product and if it is small size only down side cell will give sigal and that product it will be registored as bad product and when it reach the pusher it will be rejected ( counting by encoder signal )
any one has information please help
Leza
Leza,
How can we help? What information do you need to solve this problem?
If you search for Bit shift registers, you will find a lot of similar PLC programs that use encoders to track packages. It requires a sensor that detects a package POSITION and inserts a bit into a Shift-Register. The Shift Register is a sequential series of memory locations, length set to match length of conveyor. Each time the conveyor moves 1 Increment (100 milimeters, 1 meter, whatever units needed), the Encoder causes the Shift Register to move 1 Bit position, thus "tracking" the movement of the package. When the bad package arrives at the Pusher (determined by monitoring the bit in the Shift register that corresponds to the physical distance between Pusher and sensor location), you trigger an output to push it off.
Perhaps this thread will help you understand Shift Registers.
http://www.plctalk.net/qanda/search.php?searchid=1059574
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
195
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,176
Hi All. I have a very specific question about tracking using an encoder and bitshift register. We would like to use a Compact or Control Logix PLC...
40
1,764
Hey all, was wondering if it was possible to shift values in an array of strings? I have a database that I am loading up with "Users" in the...
315
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
700
