Shopping for a Sensor/Solenoid
KingPresident
Aug 2015
Michigan
138
Resistance welding: we use air pressure to amplify weld gun tip force on the spot welds. The shop air compressor is shared, so pressure and volume supply can vary depending on the moment. I'm looking for a sensor/solenoid setup that can self correct the scale value/amplitude to maintain constant tip force regardless of the varying incoming air pressure.
Right now, we use an SMC bank with solenoids that are simple two way valves with a diaphragm adjustment that controls nothing... They are just open or closed, and the best I can get right now is the diaphragm adjustment at the time of configuration.
Do any of you have a recommendation? Would like 4-20ma input and output
+1 pressure regulator, although it only REDUCES the pressure.
If you want to ride through pressure dips, you will need
Incoming line - one way valve - accumulator - pressure regulator - to your solenoids.
Hi all, I'm fairly new to the PLC world and am currently working on designing a portion of a ladder logic diagram for a group project. I was...
2,865
Hey All. I have an opportunity to do a small monitoring project for a gentleman with 8, 25 foot (approx.) tall liquid vessels. Given the specific...
17
4,746
I'm quoting on a job for a conveyor line. We have 17 sections of 20' conveyor, approx 1/2HP motor/drive on each. Customer wants to be able to vary...
32
8,928
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
63
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
114
