ShortCuts to InTouch 9.5
andrzejplo
Mar 2006
Kraków
22
Hello,
I am looking for some shortcuts list in Intouch 9.5.
There are very helpfull in desinig.
Duplicate (but not CTRL+C);
Make Symbol;
Breake Symbol;
SmartSymbol - Generate,Edit....etc.
Thanks for answer
Keys....
Here are the ones I've been using for years. The following will come in reall handy when your converting windows after you import them.
F2 = selects everything on screen
Ctrl + E = Brings up Substitute taganames screen
Ctrl + L = Substitute Strings
Others I've used:
Ctrl + T = Brings up Tagname Database
Ctrl + W = Brings up Current Windows Properties.
I've used Wonderware for a long time now and actually just got certified as a CSI (Certified System Integrator). The test was definately no walk in the park.
Hope this helps.
Shortcuts
Hello,
Do You know some quick way of switching between windows?? I have 10 Windows opened and I want to quickly switch between them
Like CTRL+TAB in Microsoft Applications?
Thanks for answer
There is no shortcut keys that I know of that will alow you to do that. I just checked some literature and can't findy anything on that.
If anyone know of a way maybe the will read this and help.
Only way I know is to press Alt-W then use the mouse or arrow keys to select the screen of your choice from the top window menu bar.
Shift+Alt+! (Shift + Alt + Exclaimation point) can be used to quickly go back and forth between development and runtime.
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple. I have 4 machines...
474
Hey folks I was wondering how one puts shortcuts on the logic display for instructions. A few weeks back another programmer added them for me...
981
Hello, I am pulling my hair out trying to setup Modbus Master Read/Write Commands on a Prosoft MVI56E-MCM attached to a Clogixs 1756-L82E PLC. It...
1,581
Hi, I'm very new to programming in ladder logic, and wondered if there was a good resource for shortcuts. For example, if I'm looking at a main...
6,386
Hi all, -RSLogix 5000 I'm getting tierd of right-clicking and press "close routine" to close a routine, not super exhausting :), is there any...
3,942
