Shorted SCR C
fgoodsky
Apr 2021
mn
27
Ima getting a fault on my allen bradley flex, says Fault #6 Shorted SCR C. Ive googled and cant find where to look for the scr. anyone have a diagram of where to look for this scr? Any help greatly appreciated.
A-B has made VFDs for decades, and there are at least four hardware families with the name "PowerFlex".
Please post the model, and ideally the size (HP or kW or Amperes) or part number of the drive, and folks may be able to direct you to a troubleshooting and repair guide.
as stated we need more information the origenal manufactured date may help
early VFD's used SCR's on both the incoming power bridge and as well as the output power section. ether way it's time to consider an upgrade other components may be ready to fail as well. Some VFD's just aren't worth the time and expense of a repair
Hi All, We have about 13Pcs of SMC3 installed which drive about 4 sets of motor each, the total motor load in each Softstart is within the SMC3...
6,811
Just looking to learn something today.... My understanding is that an output shorting on a SLC Triac card is a pretty standard card failure, with...
2,372
I an editing a program pulled from a running machine and noticed a lot of Warnings "Shorted branch detected" I am pretty new to 5000 and have used...
2,331
I got called to do some updates on a pump control panel for a waste treatment system and found a few lines in the running PLC (SLC5/04 1747-L542B)...
6,037
How can I search for shorted branch in a large RS Logix 5000 Program. I think there is a lot of themm and would prefer to not do it in a manual way.
3,735
