SICK Flexi Soft - a wird bit
JohanM
Sep 2015
Terchová
53
Hi guys.
Have someone experience with SICK Flexi Soft programmable safety controller?
I have little problem. I have this configuration: Flexi Soft CPU0 (FX3-CPU000000) fw. v3.0.03.0 and ethernet gateway FX0-GENT00000 fw. v2.05.0.
I have AB CompacLogix L24ER-QB1B and I communicate with that safety controller. On the PLC side I'am setting output bits for safety controller. On the SICK side I see these bits (their states 0/1).
Problem is with first bit in first word of data, which I am reading. If I set this bit to "true", on SICK side is in "true". When I reset it to "zero" on PLC side, on SICK side it stay in "true" until I change some another bit from this word.
Problem is only with this one bit.. Other bits in this first word "works" normal. Also bits from another words, which I am sending..
On PLC side I dont use that first bit in sw. I just set him in Tag monitor. I have only working hw configuration, no logic.
Have someone some sugestion? :confused:
Sorry for my english :)
We have experienced the same issue, but only in 1 of 4 controllers. Were you able to resolve this issue?
Called SICK- KNOWN BUG - Still not fixed.
Use another word, don't use the first word
Thank you for reply. I also used another word and its works fine. Next I had another problem with Sick Ethernet/IP Gateway. It was not able to start communicate with PLC after power cycle. It stuck in some state without possibility to ping it or something. We have to change that gateway with another piece.
Hi all, I was hoping someone here may be able to help. I've got to add a Sick Flexisoft CPU0, with a GENT 00000 Gateway attached, to an existing...
3,316
I setup a Flexi Soft system through the designer. All modules have green lights, except for the FX0-GENT status light flashing Red/Green...
3,458
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
242
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
98
I have a CLV630 scanner successfully communicating with a Micro850 controller (over Ethernet/IP) but I don't know how to convert my scan...
825
