Using CLV630 sick scanner with a micro850
Fraser
Mar 2023
Scarborough
I have a CLV630 scanner successfully communicating with a Micro850 controller (over Ethernet/IP) but I don't know how to convert my scan information into a useful PLC instruction.
The CLV630 has been set up as a Generic Device in the Micro850. I can see the CLV630 listed in the Controller Variables but I can't figure out how to retrieve the barcode information (scan results) so I can use it for a PLC instruction.
I have some PLC experience but mostly for basic control circuits. I've never incorporated a barcode scanner into ladder logic before and I'm finding it to be a steep learning curve.
To give a brief overview of this project, I'm trying to use a barcode scanner to divert boxes into one of two divert lanes.
Any help solving this issue or recommending some resources that could help me better understand how to use bar code scanners with PLC's would be much appreciated.
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
