SICK IDM Barcode Scanner through RS232 to Fanuc 120i Arcmate Controller
cschlue
Nov 2013
Davenport
34
Has anyone here ever used a barcode scanner to set a string register for program selection on a fanuc arm? Normally I would connect the scanner to an AB HMI and use it as a Wedge device to write a value to either a single register or string register depending on the barcodes being scanned but in this case I don't have the option of using an HMI.
I'm not using a PLC and only have the robot controller to interface with, I'm assuming I connect the base station of the Scanner to the controller through Serial/RS232 but I don't know how I read values from that interface.
Any direction would be greatly appreciated, Thank you.
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
240
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
96
I have a CLV630 scanner successfully communicating with a Micro850 controller (over Ethernet/IP) but I don't know how to convert my scan...
823
Banner , Sick , etc. Slot on Fork Sensors . Do they make them wider than 8.66 " ? Good Morning , I have product that is coming down the...
1,029
I've inadvertently tick the DHCP box in the sick software and uploaded this in the PLC (Sick FX0-GENT) and now i am unable to connect to it. Is...
999
