SICK safety floor scanner communication problems
:ROFLMAO: Help us to help you!
Which model?
What is the error?
How are you trying to connect?
etc etc etc
It's a pls, using a null 232 on com 1. The software "communication wizard" helps you get nowhere. I know rslinx will hog com 1 on other apps, but that's not it, I was hopeing it was something like... When connecting to an ENI you have to connect during a power up. But that's not it either. That I learned the hard way, as with most things, though.
Do you have access to their tech support line ? I worked with many of SICK's start-up techs, who were ultra-knowledgeable, and when they were in the office, they answered the phones on the tech help line- you might have to call your distrib. first to get the number (I've changed jobs and lost the 800(?) number... We usually used the CLV scanners though.
Have you your checked your serial port settings ? 9600/8/N/1 type stuff ?
-John
Here is the manual:
http://www.lpc-uk.com/sick/file1.pdf
P41 details RS232 cable pinout - check it against your cable.
P45 details the procedure to connect to a PLS via PLS/LSI software.
Is the scanner working ok? if it is kaput you wont be able to talk to it to run diagnostics.
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
254
I'm an in-house maintenance tech, and have little experience with SICK safety systems. We are going through an expansion and we have a lot of...
1,722
I was wondering if anyone has had much experience with using the SICK S300 Safety laser scanners on guided vehicles (AGV's). We are looking to...
2,342
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
103
I have a CLV630 scanner successfully communicating with a Micro850 controller (over Ethernet/IP) but I don't know how to convert my scan...
828
