Tim Ganz
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus Ascii and RTU and is set up for RTU. I am trying to use a Modbus gateway on the other end that goes from RTU to TCP but on the serial side the gateway can be set for RTU master or slave and the manual does not seem to call it out.
Does anyone ever have any experience with this module or 545 PLC?
MODNIM Manual
https://cache.industry.siemens.com/dl/files/913/17516913/att_76257/v1/505-8122-1.pdf
PLC Manual
https://cache.industry.siemens.com/dl/files/465/17518465/att_106091/v1/545-8101-2.pdf
MODNIM Manual
PLC Manual
