Siemens AI module SM331 - Measuraing Range Module Setting for Tyco PentAir E/P valve?
DenZ_P
Jun 2016
SomeWhere
64
Hello Experts,
I am going to be integrating an AI module into an existing panel and wants to know what should be measuring range setting when i am going to wire a Tyco Control valve?
Below is an image of the Side of the AI module and it is set at current factory setting "B" position as voltage. Refer to image 2 for other settings.
Measuring range Positions:
What measuring group should I set it to for the Tyco Control valve?
I have also attach the link of the Siemens AI manual I am reading.
Siemens AI Module SM331
Thanks! 🤞🏻 🍺
Hi! Doing a lab project with two 1214FC. Got a warning about reintegration of modules wasn´t configured and tried to do that. Found the two...
801
I have a 6ES7 421-7DH00-0AB0 card with the INTF LED illuminated red. This internal fault on the card is preventing the CPU from going into run...
1,107
On the Siemens IM153-1 Interface Module, ET200M, what is the difference between the "0 X-18/19/20" and the "1 x-8/9/10? Picture attached of the...
1,277
Any manufacture recommendation for remote I/O for Siemens PLC.
2,917
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,163
