Siemens CP340
RdW
Oct 2013
Weesp
All,
one of our industrial printers we do represent is communicating with a Siemens CP340 RS232c PLC through a comms cable which is only using pin 2,3 and 5.
Due to other needed functionality in our printer I have to load other firmware into it ; after this the red LED on the Siemens in on and no communcation is possible anymore. When going back to the original firmware everything is back working again.I tried this on several production lines with on every line the same negative result.
The only settings I can do on my printer are baudrate and node number (1) but I can't think of any reason why the firmware only would spoil the RS232 connection.
Next to this I am trying to understand HOW the Siemens is checking the RS232 connection to get an idea what could be wrong on our side.
I am absolutely not a PLC expert but am open for any helpful suggestion what to check , ideas etc.
Thanks,
Ruud
Hi, been looking everywhere for this info but cant find it. Does anyone know if the CP340 RS232 card supplies 5v to Pin 9. Thanks
1,420
Hello, We have a Sartorius CP scale connected via RS232 to the PLC. All was working well but when the scale was replaced with a newer version...
2,548
I am trying to only receive data from a device via serial communication. I can read the data through my com port on my computer so I know that it...
1,702
Hi folks, I could really use some help - I am trying to connect CP340 with my PC by RS232 protocol. I need to send some characters to PC from...
1,902
Hello, I have 3 balances connected on RS232 at very low speed (2400bps). All 3 make good communication. But, after a day or so, 1 or more...
3,716
