Siemens DriveMonitor
blima
Aug 2010
Lisbon
96
Hi!,
Does anyone have tutorials/basics of using DC Drive with the Siemens DriveMonitor software?
I would appreciate if someone could point me also to micromaster/driveMonitor tutorials.
Thanks in advance,
Bruno
I created a set of directions with screenshots for how to use DriveMonitor. It pretty much walks you through going online and uploading/downloading.
Zipped up the file size is 384kb which exceeds the 300kb allowed here.
Shoot me a PM with your email address and I'll send it to you.
I'll look into posting it on rapidshare and providing a link here. I think it would be helpful to anyone that needs to use DriveMonitor but doesn't know the steps.
Dear Experts,
I know its an old thread, but I am desperately needing your help regarding SIMOREG and DriveMonitor here.
Basically I have done everything I can based on my browsings on the internet.
I made the X300 to Serial cable, using the schematic provided by some guys that said we have to connect the 1-9-5 to the GND, etc.
I also checked the Drive parameter and DriveMonitor parameter.
But my drive is still not detected in drivemonitor.
My questions are:
1. Do I need to have the same firmware in DriveMonitor and the SIMOREG?
2. The drive is currently connected via SST-2 to a PLC. Can I still connect through SST-1?
3. How to set the PZD in DriveMonitor before we connect to the drive?
Thanks for your attentions. Please help us here. I don't know what to do anymore.
The SW version is 3.1. Does it mean I cant connect?
Basically the drive is in use and I need to access it while running. I dont want to tamper with the parameter already inside so I didnt create an empty parameter or factory setting project.
I want to do the "Set up an USS ONLINE connection..." command from FILE. Can't I do this? Even if I dont have any project opened, I should have been able to see the drive there, right?
As for the cable, I set one up using schematic in http://www.plctalk.net/qanda/showthread.php?t=36695
I have seen in some threads that I have to set the PZD first in "Drive ES Manager" or something. I can't access this file and I don't know how to change the PZD without an empty parameter set or something....
Yes. You can still connect
But I would just set your drive monitor project to 3.1
I think you might misunderstood something. Please take a look at below picture.
What I want to do is to Find Online Drives. How can I set the SW version beforehand?
Or I can't do this for SIMOREG?
Also, some guys said that I need to set PG/PC interface in control panel. But I can't find the "PC COM -PORT (USS)" right now. Or should I be able to see that if I connect the cable? (I am currently not in front of the drive now)
Thanks,
Fajar
Hi all. I am using Siemens STARTER to connect to MicroMaster 440's. STARTER uses the S7ONLINE connection to go online, so I can go online via...
8,057
277
161
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
125
