Siemens DriveMonitor
blima
Aug 2010
Lisbon
96
Hi!,
Does anyone have tutorials/basics of using DC Drive with the Siemens DriveMonitor software?
I would appreciate if someone could point me also to micromaster/driveMonitor tutorials.
Thanks in advance,
Bruno
I created a set of directions with screenshots for how to use DriveMonitor. It pretty much walks you through going online and uploading/downloading.
Zipped up the file size is 384kb which exceeds the 300kb allowed here.
Shoot me a PM with your email address and I'll send it to you.
I'll look into posting it on rapidshare and providing a link here. I think it would be helpful to anyone that needs to use DriveMonitor but doesn't know the steps.
Dear Experts,
I know its an old thread, but I am desperately needing your help regarding SIMOREG and DriveMonitor here.
Basically I have done everything I can based on my browsings on the internet.
I made the X300 to Serial cable, using the schematic provided by some guys that said we have to connect the 1-9-5 to the GND, etc.
I also checked the Drive parameter and DriveMonitor parameter.
But my drive is still not detected in drivemonitor.
My questions are:
1. Do I need to have the same firmware in DriveMonitor and the SIMOREG?
2. The drive is currently connected via SST-2 to a PLC. Can I still connect through SST-1?
3. How to set the PZD in DriveMonitor before we connect to the drive?
Thanks for your attentions. Please help us here. I don't know what to do anymore.
The SW version is 3.1. Does it mean I cant connect?
Basically the drive is in use and I need to access it while running. I dont want to tamper with the parameter already inside so I didnt create an empty parameter or factory setting project.
I want to do the "Set up an USS ONLINE connection..." command from FILE. Can't I do this? Even if I dont have any project opened, I should have been able to see the drive there, right?
As for the cable, I set one up using schematic in http://www.plctalk.net/qanda/showthread.php?t=36695
I have seen in some threads that I have to set the PZD first in "Drive ES Manager" or something. I can't access this file and I don't know how to change the PZD without an empty parameter set or something....
Yes. You can still connect
But I would just set your drive monitor project to 3.1
I think you might misunderstood something. Please take a look at below picture.
What I want to do is to Find Online Drives. How can I set the SW version beforehand?
Or I can't do this for SIMOREG?
Also, some guys said that I need to set PG/PC interface in control panel. But I can't find the "PC COM -PORT (USS)" right now. Or should I be able to see that if I connect the cable? (I am currently not in front of the drive now)
Thanks,
Fajar
Hi all. I am using Siemens STARTER to connect to MicroMaster 440's. STARTER uses the S7ONLINE connection to go online, so I can go online via...
8,085
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
135
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
83
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
172
199
