Siemens STARTER and Drivemonitor.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,325
Hi all.
I am using Siemens STARTER to connect to MicroMaster 440's.
STARTER uses the S7ONLINE connection to go online, so I can go online via the Profibus CP's that are installed in each MM. So far so good.
But there is no USS connection available in the Set PG/PC Interface utility. Does that mean that STARTER can ONLY connect via Profibus ? USS is not possible ?
On the other hand, the DriveMonitor software can connect via USS, but I think that it cannot connect via Profibus.
I would like to have the possibility to use the STARTER software, but also to have the fallback solution to connect via USS on a serial link.
Does anybody have an idea ?
Starter can connect via USS. In the Set PG/PC Interface select "PC COM-Port(USS)". If it's not available, you will have to add it by clicking the Select button in the Interfaces section of the same Set PG/PC Interface pop up. I used it with the PC MM4 Connection Kit (6ES6 400-1PC00-0AA0) to configure two MM420s with Starter.
As for DriveMonitor, I have not used it. Perhaps I am reading too much from your post, but are you able to connect via USS using DriveMonitor but not Starter? If that is the case, I am confused. I assume that you have to select USS from the Set PG/PC Interface for DriveMonitor, so should it not also work for Starter? Either way, I hope this helps!
It certainly did help.
Sure enough, there is a "PC COM port(USS)" entry in the Set PG/PC Inteface utility. It wasnt there before, but now it is, appearantly after I have installed STARTER. I just didn't notice it.
DriveMonitor uses its own interface (not the PG/PC interface that is used in STEP7 etc). Thats why I could go online via a serial link with DriveMonitor.
It says in Siemens documentation that STARTER is recommended for MM420-MM430-MM440, whereas DrievMonitor is recommended for older drives - I dont know why, I could go online and configure MM430 and MM440 with DriveMonitor before.
It looks like STARTER is a cutdown version of DRIVE ES, so it should be the way to go anyway.
I need to change a parameter to a drive in Starter. I know just enough about Starter to get me in trouble. Is this correct procedure.... When...
1,581
Hi, I am interested in buying a Siemens starter kit. I came across this site, realpars.com Does anyone know if this is a reputable company?? Any...
1,183
Hi All, I have a Simens CU320 drive controller that I wish to connect to via the X127 ethernet port. The unit communicates with the CPU vua...
4,098
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,570
I would like to do an auto tune on a Siemens drive in an existing project in Starter. I have looked at the manuals and some videos but most...
2,070
