Siemens Error : \Flash\Simatic\PDATA.FWX
asteroide
Jul 2010
der
158
Hello Friends
I have this error in a MP277 8" Touch.
The "\Flash\Simatic\PDATA.FWX" configuration file could not be loaded.
The application will be terminated.
I do not have the source code, but I have a folder called Simatic with some dlls files and a HMIRTM.EXE and PDATA.FWX file and anothers files.
How can I download this application to the hmi?
Thanks in advance.
If you don't have original app backed up, I think that you don't have straight forward solution.
The pdata.fwx file in the offline folder is probably the runtime file that you need. I think that it is possible to copy it over to the panel. But maybe the real issue is that the flash memory on the panel is gone.
Do you have a spare panel ?
Does the existing panel allow you to open the windows control panel ?
The dll files could be files needed on the panel as well. I think that the folder that you have is actually a backup from the panel that has been unpacked.
Hi everyone, i have a Siemens S7-300 Cpu 314C-2 DP with several cards of i/o and servos my laptop has TIA version 16 and 17 loaded and...
167
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,580
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,784
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,536
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,165
