Siemens Logo! or Idec Smart relay connector
Wanderer
Jan 2006
Hallo and Happy new year to all
I am looking for the connector in the attached picture but I can't find it anywhere.It is for the serial connection of the logo! or the smart relay with a pc.Can somebody help me?
Thank you
Thank you
That is a custom connector and will be very hard to find.
That is the exact same cable as the Idec Smart relay cable. You can order the cable for about $70 from Allied Electronics Part # 814-1125. Sorry can't be of more help..
Answer
The distance : Pin from pin is 1 mm
The dimension of the rectangular connector is 5.5mm x 5.5mm
The photos are in real dimensions.
Thank you for your answers.I am still searching without any luck yet.
Greetings. A guru at IDEC told me I could use the Windlgc software to talk to the Siemens Logo! Smart Relay. I can't get it to work. Has anyone...
14,939
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
296
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,081
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,047
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,414
