Siemens LOGO! question
Coralreef
May 2006
Dk
23
Hi all
On a Siemens LOGO i need to change an output from no 1 to 3 - reason is that output 1 is damaged and output 3 is free :D
I dont have software on the PC so im trying on the display/buttons on the LOGO.
Offcause i could write down all the code made on Q1 and proghram it again on Q3, but its a rather large part so i would rather just change 1 to 3 some how ???
Can it be done easily ?
Hi
How about a simple piece of code
something like this
A Q1
=Q3
Q1 Q3
never used a logo, but should be simple enough to impliment
hope this helps
Neil B
Year ofcause why not just do a program on Q3 that says if Q1 then Q3 !!!
Im not a logo user either i mostly do S400 series og Control Logix - so it was hard to even find out how to get into programming mode :D
Its my nabours heat installation thats controlled by the logo.
does it have a display .. if there is a display .. there is a way to edit the program without connecting your PC to the controller. you have to read the LOGO! manual.
I wish you luck !!!
I have wrote many times I am new to programming but I feel I am picking it up quickly with everyone's help. I have only worked with Allen Bradly...
2,154
Hello, I want to buy Siemens LOGO! 12/24RC 6ED1 052-1MD00-0BA6. I need to control temperature of liquid by 2 state regulation(on/off) of an...
6,465
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
290
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,079
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,046
