Siemens Masterdrive inverter supply from simodrive rectifier
Kataeb
Jan 2007
www.livelovelebanon.com
636
We want to install the following hardware on a machine with siemens simodrive
rectifier:
Servomotor, Siemens, 1FK7032-5AK71-1TG2
Masterdrive inverter, compact plus, motion control, Siemens, 6SE7012-0TP50-ZC33+G91
Can we supply the Masterdrive inverter from the simodrive rectifier dc output?
What hardware do we need to connect it? (fuses, cables, clamps,...)
Has someone tried it before? Is it safe?
Thank you,
I am not sure if this will help you but once I used the Micromaster Rectifier DC-link for a simovert MC. because I had problem with the original rectifier. I did use this for one month I had no problem.
May be I was just too lucky...
was the micromaster rectifier dc-link voltage equal to the value needed on the simovert mc (540vdc)? what hardware did you use to do the connection?
i have never worked with simodrives, that's why i am not sure what to do with the simodrive infeed module dc-link output. does anyone has the manual of this item?
thanks
There is an option on the Masterdrive MC that can set the DC voltage feeded to the system
hi everybody
i ve mm440 and masterdrive mc (dc/ac drive).
can i supply dc voltage from mm440 to masterdrive mc?is it possible?
but i think if its ok, we drive to motor from masterdrive , i think alarm or warning code that can be appered on mm440 , bcause of dc link?
I am working on a project to back up software for a number of machines for a client, and am having problems connecting to SIMOVERT MasterDrives...
3,150
I have a siemens DC-AC masterdrive part #6se7016-1ta51-z that is coming up with an alarm A 129 at random, it will run for hours and then throw up...
1,554
This is slightly OT but I hope some of our members who use Siemens AC variable frequency drives can help me out. I am trying to diagnose some...
11,873
Hi, I am using the Drive Monitor software Ver 5.4.0.1 (Free comes with drive). It is working Ok to upload download parameters but I am unable see...
4,239
Dear Sirs, We are trying to use Siemens CFC Blocks to parameterize and monitor a simovert masterdrive motion control (check the attached file)...
3,367
