Siemens Memory Cards
kike
Jan 2006
spain
Hi all,
Simple question, Where can I get drivers to read Siemens memory cards in my computer's (no siemens) PCMCIA slot?
I have had a look in siemens support web, but without any result.
If also you have another way to read/write this kind of memory card, it will be very helpfull.
I think it is not possible to use these cards in a PCMCIA slot, this despite that they are physically exactly the same as PCMCIA cards.
Siemens sells a card reader/writer for the S7 MC, S7 MMC and S5 Memory cards. Type # 6ES7792-0AA00-0XA0. List price approx 1000 Euro !
Apart from that, if you are using the MC cards for S7-400, then you can program the MC card when it is sitting in the CPU.
Thanks Jesper, you may be right.
Anyway, just a point. I have insert the memory card in the PCMCIA slot and the HW controller reads it as PCMCIA card. So, if it is only that my software can not read/write on it, it's because I don't have the right driver installed. I think that Siemens's card read/writer may have these drivers on it, and Siemens doesn't give them in other way because they want continue earning that 1000 euro, don't they?
We use S7 400 PLCs on our site, together with 1MB Falsh EPROM cards and battery backup installed. The PLCs were supplied by the vendor with this...
11,487
Hello plc people! One question about memory cards in the Siemens plc's... In the old CPU 315-2 DP we were using EEPROM. Then we had to Copy...
4,148
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
330
Sorry for the basic question: On my HMI, I've created a button labelled SAVE to save the current values (distances in mm). It's not linked to any...
22
2,269
Hi Guys, Is there any way of compressing the "Work Memory" of a Siemens S7 1200 CPU. I did change the installed card from a 4mb to a 12mb. I...
9,069
