Siemens micromaster 420 profibus
italo2008
Feb 2009
Padova
95
Hi
I've a micromaster 420 motor drive, with profibus connection to PLC.
I have a AWL function wich read the status word and send the command word to the motor drive, with its speed reference.
when the drive is fault, once the emergency is reset (it doesn't exist anymore), if I I want the motor start to run, I need to ack the emergency, and, if the on/off1 signal is high, i must reset it for a while.
The question is: is it possible to avoid acking the fault? in this way, if I have ther's no more fault or emergency and the ON signal is high, the motor start to run immediatly and I don't need to reset and set the ON signal...
Is this legal in Italy? You can automatically reset the E-stop but for the machine to move/Start you need to Ack.
Hello Everybody, Recently we changed the gearbox which has different ratio than the original one on a motor which is controlled by Micromaster...
1,901
I've been trying to find the max voltage rating of the 24VDC digital inputs on the Micromaster 420/440 drives from Siemens. I have found the...
3,266
Hello guys, i am new on this forum, i need help in programming siemens s7 200 with micromaster 420 that is connected with motor. I know how to...
5,118
I was just wondering if the devicenet communication module for a micromaster 420 comes with the plug that device net cable plugs into. THe plug...
4,136
Hi Does anyone know what and how much torque control options a have with a motor running on a Siemens MicroMaster 420 frequency...
5,139
