Torque control with Siemens MicroMaster 420
Coralreef
May 2006
Dk
23
Hi
Does anyone know what and how much torque control options a have with a motor running on a Siemens MicroMaster 420 frequency inverter(controlled by a S7400 plc) ?
Im pretty blank on that subject !!
Thanks !
Coralreef said:
Does anyone know what and how much torque control options a have with a motor running on a Siemens MicroMaster 420 frequency inverter(controlled by a S7400 plc)?
Hi
Unfortunately I have to dissappoint you. It is not possible within MM420 because there in no Vector control option. With MM440 its possible when selected "control mode" is 20 or higher. Torque limits are in parameters (constant P1520 / P1521) and ("external" control / variables P1522 / P1523).
Pete (y)
Damn - my bad :D
It is a 440 im getting :D
So thanks for the info - i will take a deep plunge into the datasheet on monday when i get back at work !
I have found most parameters and i think i will set it up in STARTER(in the VLTs expert list) to run between 0 and 100% (Lower/upper settings).
And then control the actual value by parameter P1503 - set point.
Other than that i have P1500 to CB on COM Link !
But am i missing some settings or parameters ?
How do i transfer the value to the VLT - im getting kinda lost in all them PKW PZD words !!
We wish to use Siemens MM440 in extrusion application, where motor works in torque control mode in one direction and speed control mode in reverse...
5,292
Dear All !! We are going to use Micromaster MM440 for puller application in Extrusion process. Problem is how to changeover...
3,362
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
285
Hello all, I am using a PowerFlex 700 (Rev 10.001) to maintain tension in a web. We're reading lbs from load cells under one of the rolls...
85
11,634
Hello, I have an application where 80% of the time, an operator will be needing to issue very accurate MAM or MAJ instructions to a Kinetix 5500...
710
