Siemens Micromaster 430 BOP2/AOP
504bloke
Jan 2005
Down South
2,721
Hi
Can i plug an AOP into a siemens 430 MM invertor ? The AOP is listed for the 440 only, the 430 uses the BOP2 ?
Reason i ask is i just had a drive repaired by an siemens repairer and the drive has come back with the same fault as it was shipped with
F001 (Overvoltage fault)
Bearing in mind there is no problem with the voltage or motor on site and when the F001 fault appears on power up the BOP2 keypad is locked and you cannot do anything.
The repairer has told me its the OP station causing this and that if i change it to an AOP the drive will work ???
Well firstly the AOP isnt listed for use on the 430 and secondly i cannot see an op station causing an OV fault ?
I have got an AOP and BOP2 coming out tomorrow to try but to be honest i think the repairer is talking horse manure!
Any Comments welcome
Hi Dave,
You pretty much got it right....
Kevin
It is first time we are working with CANOpen. There is a task to control Siemens Micromaster430 from Modicon M340. We've got EDS from Siemens...
5,187
Anyone have any experience with these critters? Looking to control process water pressure in injection molding operation.
5,669
Hello Everybody, Recently we changed the gearbox which has different ratio than the original one on a motor which is controlled by Micromaster...
1,902
Hello Experts I have to to make a backup of Siemens micromaster mm 440 with RS 485 to terminal 29&30. I use starter or drive monitor Do i need...
1,209
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,980
