Siemens MicroMaster 440 Control Through S7315 PLC
Thanks. Do I just have to paste this code into a FC block? Also, do I have to call FB41 seperately? (Is this the convert to analogue block?)
I have been thinking about my problem and am not sure if the solution would be for PID control (this may be over-complicated for the task), but to implement a set of rules for when the pressure reaches a particular threshold, send a speed reference to the drive.
I have attached an Excel file of when I need the pumps to start decreasing speed.
Could someone agree what the best control method would be?
Many thanks in advance
Use a 40 point lookup table for each drive. The table will contain 40 speeds corresponding to the 40 pressure points.
To me it looks like 4 straight lines.
A look-up table would be overkill.
Simply use a scaling function that defines y=f(x) by means of the end points. The end points could be set on a HMI for example.
Here's the code for a straight line implementation.
For your pink line:
S1_Constant=100.0
P1_Constant=20.0
P2_Constant=30.0
Code:
FUNCTION FC 3 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  S1_Constant : REAL ;
  P1_Constant : REAL ;
  P2_Constant : REAL ;
  Pressure : REAL ;
END_VAR
VAR_OUTPUT
  rSpeed : REAL ;
END_VAR
VAR_TEMP
  rSlope : REAL ;
  rC : REAL ;
END_VAR
BEGIN
NETWORK
TITLE =calc slope and intercept
	  L	 #P1_Constant;
	  L	 #P2_Constant;
	  -R	;
	  L	 #S1_Constant;
	  /R	;
	  T	 #rSlope;
	  L	 #P2_Constant;
	  NEGR  ;
	  L	 #rSlope;
	  *R	;
	  T	 #rC;
NETWORK
TITLE =check for which region to use
	  L	 #Pressure;
	  L	 #P1_Constant;
	  <=R   ;
	  JC	less;
	  TAK   ;
	  L	 #P2_Constant;
	  >=R   ;
	  JC	more;
	  JU	linr;
NETWORK
TITLE =linear part
linr: L	 #Pressure;
	  L	 #rSlope;
	  *R	;
	  L	 #rC;
	  +R	;
	  T	 #rSpeed;
	  JU	Exit;
NETWORK
TITLE =less or more part
less: L	 #S1_Constant;
	  T	 #rSpeed;
	  JU	Exit;
more: L	 0.000000e+000;
	  T	 #rSpeed;
	  JU	Exit;
NETWORK
TITLE =
Exit: SET   ;
	  SAVE  ;
END_FUNCTION
Many thanks for the help, it is greatly appreciated. The only thing is that I am only really used to FBD/LAD and have not used a lot of STL.
Could this function be implemented by FBD/LAD?
Regards,
henno2000
Here's the same processing in ladder. You have to import the source code and compile it - it will then view in ladder when you open the block.
Code:
FUNCTION FC 4 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  Pressure : REAL ;
END_VAR
VAR_OUTPUT
  rSpeed : REAL ;
END_VAR
VAR_TEMP
  rSlope : REAL ;
  rC : REAL ;
  bLess : BOOL ;
  bMore : BOOL ;
  bLinear : BOOL ;
  rTemp : REAL ;
END_VAR
BEGIN
NETWORK
TITLE =calc slope
	  A(	;
	  L	 #P1_Constant;
	  L	 #P2_Constant;
	  -R	;
	  T	 #rTemp;
	  AN	OV;
	  SAVE  ;
	  CLR   ;
	  A	 BR;
	  JNB   _003;
	  L	 #S1_Constant;
	  L	 #rTemp;
	  /R	;
	  T	 #rSlope;
_003: NOP   0;
NETWORK
TITLE =calc intercept
	  A(	;
	  L	 #P2_Constant;
	  NEGR  ;
	  T	 #rTemp;
	  SET   ;
	  SAVE  ;
	  CLR   ;
	  A	 BR;
	  JNB   _00b;
	  L	 #rTemp;
	  L	 #rSlope;
	  *R	;
	  T	 #rC;
_00b: NOP   0;
NETWORK
TITLE =determine which region to use - pressure less than P1
	  L	 #Pressure;
	  L	 #P1_Constant;
	  <=R   ;
	  =	 #bLess;
NETWORK
TITLE =determine which region to use - pressure greater than P1
	  L	 #Pressure;
	  L	 #P2_Constant;
	  >=R   ;
	  =	 #bMore;
NETWORK
TITLE =Linear region
	  AN	#bLess;
	  AN	#bMore;
	  =	 #bLinear;
NETWORK
	  A(	;
	  A	 #bLinear;
	  JNB   _013;
	  L	 #Pressure;
	  L	 #rSlope;
	  *R	;
	  T	 #rTemp;
	  AN	OV;
	  SAVE  ;
	  CLR   ;
_013: A	 BR;
	  JNB   _017;
	  L	 #rTemp;
	  L	 #rC;
	  +R	;
	  T	 #rSpeed;
_017: NOP   0;
NETWORK
TITLE =less region
	  A	 #bLess;
	  JNB   _01b;
	  L	 #S1_Constant;
	  T	 #rSpeed;
_01b: NOP   0;
NETWORK
TITLE =more region
	  A	 #bMore;
	  JNB   _021;
	  L	 0.000000e+000;
	  T	 #rSpeed;
_021: NOP   0;
END_FUNCTION
Many thanks for the help. It is greatly appreciated.
For the above block, I am wanting to send the output 'rSpeed' to the drive as a speed reference, but am unable to do so (IE - DB44.DBW4). This is because the output is a REAL, when I am wanting to send a WORD. Is this simple to change for the structure of the block? (To have a WORD output).
Regards,
henno2000
To convert a REAL to an INT:
L "rSPEED"
RND
T "iSPEED"
Notice, maybe you have scaled the iSPEED so that you want to use part of what is after the decimal point.
I.e. iSPEED=1234 means "123.4"
If that is the case, you have to push the values to suit the decimal point.
L "rSPEED"
L 10.0
*R
RND
T "iSPEED"
Also, be sure that rSPEED cannot exceed what can be fit inside an INT, -32768..+32767. Check your scaling.
Here's the block updated to output a word where 16384 corresponds to 100% speed.
Code:
TITLE =
VERSION : 0.1
VAR_INPUT
  Pressure : REAL ;
END_VAR
VAR_OUTPUT
  wOutput : WORD ;
END_VAR
VAR_TEMP
  rSlope : REAL ;
  rC : REAL ;
  bLess : BOOL ;
  bMore : BOOL ;
  bLinear : BOOL ;
  rTemp : REAL ;
  rSpeed : REAL ;
  diTemp : DINT ;
END_VAR
BEGIN
NETWORK
TITLE =calc slope
	  A(	;
	  L	 #P1_Constant;
	  L	 #P2_Constant;
	  -R	;
	  T	 #rTemp;
	  AN	OV;
	  SAVE  ;
	  CLR   ;
	  A	 BR;
	  JNB   _001;
	  L	 #S1_Constant;
	  L	 #rTemp;
	  /R	;
	  T	 #rSlope;
_001: NOP   0;
NETWORK
	  A(	;
	  L	 #P2_Constant;
	  NEGR  ;
	  T	 #rTemp;
	  SET   ;
	  SAVE  ;
	  CLR   ;
	  A	 BR;
	  JNB   _002;
	  L	 #rTemp;
	  L	 #rSlope;
	  *R	;
	  T	 #rC;
_002: NOP   0;
NETWORK
	  L	 #Pressure;
	  L	 #P1_Constant;
	  <=R   ;
	  =	 #bLess;
NETWORK
	  L	 #Pressure;
	  L	 #P2_Constant;
	  >=R   ;
	  =	 #bMore;
NETWORK
	  AN	#bLess;
	  AN	#bMore;
	  =	 #bLinear;
NETWORK
	  A(	;
	  A	 #bLinear;
	  JNB   _003;
	  L	 #Pressure;
	  L	 #rSlope;
	  *R	;
	  T	 #rTemp;
	  AN	OV;
	  SAVE  ;
	  CLR   ;
_003: A	 BR;
	  JNB   _004;
	  L	 #rTemp;
	  L	 #rC;
	  +R	;
	  T	 #rSpeed;
_004: NOP   0;
NETWORK
TITLE =less region
	  A	 #bLess;
	  JNB   _005;
	  L	 #S1_Constant;
	  T	 #rSpeed;
_005: NOP   0;
NETWORK
TITLE =more region
	  A	 #bMore;
	  JNB   _006;
	  L	 0.000000e+000;
	  T	 #rSpeed;
_006: NOP   0;
NETWORK
TITLE =scale for drive 0-100 == 0-16384
	  A(	;
	  L	 #rSpeed;
	  L	 1.638400e+001;
	  *R	;
	  T	 #rTemp;
	  AN	OV;
	  SAVE  ;
	  CLR   ;
	  A	 BR;
	  JNB   _007;
	  L	 #rTemp;
	  RND   ;
	  T	 #diTemp;
_007: NOP   0;
NETWORK
TITLE =scaled value to output
	  L	 #diTemp;
	  T	 #wOutput;
	  NOP   0;
END_FUNCTION
JesperMP said:
Just a small comment:
I think it is better to format the output as INT in stead of WORD.
True, then the output can be sent straight to the drive. The drive parameter for I_Setpoint requires a reference in % (-100 to +100).
To convert to INT I have used the RND function. Is this acceptable? (The number should be limited at 100).
Regards,
henno2000
Yes. If the REAL value cannot go outside +/- 100.0 then it is as simple as that:
L "rSPEED"
RND
T "iSPEED"
Also, using the example project, I copied across DB44 & DB55, for which there were no parameters displayed. I then copied across FB63 (which contains the parameters), and everything could be viewed.
I know that I need to copy DB44 & DB55 for each individual drive, but do I have to copy FB63 for each individual drive?
Regards,
henno2000
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,975
fault A0501 (i.e current limit ) displaying whwn i replace siemens 420 drive with mm440. all parameters are crosschecked. please help to...
1,553
I have a Siemens Micromaster 440 (6SE6440-2UC25-5CA1) with encoder module (6SE6400-0EN00-0AA0) and Profibus module (6SE6400-1PB00-0AA0). I'm...
3,063
I am trying, for the first time, to write values to the control word of a Micromaster 440 using an S7-300 PLC. I barely know what I'm doing, and...
2,573
Hello good day : micromaster have a 440 installed on a machine, when I push button start machine micromaster machine works well, up to speed and...
2,169
