I believe DB50 is oly used by the HMI program. I think it uses tag multiplexing to switch which drive to display when there are several drives in the same project.
Another goofup is to start a "commisioning" by first reading from the drive, thereby loading the factory values.
When you write the parameters to the drive with the commisioning function, then the parameters are stored on the EPROM on the drive.
If you are modifying the parameter DBs, then be sure to modify the actual vals, not just the initial vals.As a second issue to this, the drives parameter information keeps resetting to the default values for the drive (230v/50Hz). How can I see the actual drive parameters currently installed, and can I get it retentive to the drive/Profibus module?
