Siemens Midimaster Vector Software
Suparoo
Oct 2013
Suffolk
Hi All,
Is anyone able to shed any light on my PC to MDV connection issue please?
Ive inherited an MDV (6SE3221-7DG50 V2.05) and am trying to use Drive Monitor V5.5 SP2 to write the params to the drive.
Uploading the param set to DM is successful but I am unable to write to the drive and opening the saved uploaded file gives an error message to the effect of 'database version 000 does not exist'.
I am using a 'poor mans' 232/485 converter cable (if you can call it that) but Im reluctant to point the finger at this because of the error message above.
Cabling/converter recommendations are welcomed.
Any insight will be gratefully received.
TIA
Hi All, Is anyone able to shed any light on my PC to MDV connection issue please? Ive inherited an MDV (6SE3221-7DG50 V2.05) and am trying to...
2,505
Is there a way to program a digital output on Siemens MIDIMASTER Vector so I could detect the fault present (like overcorrect) with my PLC? I know...
1,923
Hey fellas - Just wondering if any of you have any familiarity with the Siemens Midimaster line of drives. I have one that died, and to be...
3,280
Good morning, all I am very new to siemens family and to STL, i have been playing for two days now and manage to get the scaling do in STL. Now...
73
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
123
