Siemens MP-377 Image corrupted, won't take new image
Chadk1971
Dec 2009
Virginia
Hi all,
I have a Siemens MP-377 that is only a few months out of the box, but was on the shelf for long enough that it is now out of warranty.
It started acting up at a customer site in a new machine recently. It was not responding well to touch, slow, etc. Calibrations and re-downloading the application did not help.
I attempted to flash the image, and it hung up during the flash. I have tried numerous times to do the factory default and re-image this panel with no success. The message on the screen says that there is no image installed, and that it is awaiting an OS update.
A call to Siemens hotline walked me through the same process that I have tried multiple times, with no success. At this point the hotline tech told me that this was a problem they have been seeing with MP-377's, and I needed to send it in for it to be re-imaged.
I can't see wasting the money to get it re-imaged since I will not be using a refurb panel on a customer machine, and I can't put it back in the system as a new part after it is fixed.
I was hoping someone here might have had a similar issue and found a way to work through it?
Thanks.
I think that the only "issue" is that you are s**kered for having to pay for having the panel fixed.
In any way, the box has been opened, and the panel isnt "new" any longer.
I'm still getting used to working with Siemens Step 7 Classic, and WinCC in the Simatic Manager package. I need a trend line on the MP377 HMI, and...
1,855
i have siemens MP377 HMI which is connect to siemens S700 plc. Now i want to connect HMI with Internet so my supplier will modify my programe.so...
1,073
good morning, we have Siemens HMI MPI 377 19 inch, the screen is Black but its working, and we don't have backup. i have new screen, my...
3,893
Hi, I have a MP377 12 inch touch panel . when turn ON its show only white screen . In the RJ45 two lights always ON. I can't communicate, In...
2,803
MY MP 377 15" Touch Siemens HMI has some problem in S7 transfer setting. Option under S7 Transfer setting are showing as Inactive. If anyone have...
2,444
