Siemens MP377 15" Touch Query
kegman
Oct 2003
London
25
All,
Has anyone had any issues with siemens MP377 15" HMI touch screens.
We have recently had one installed which keeps locking up with all variables showing " hash "
Having not programmed the panel myself i just want to know if there are any common problems before we look any deeper.
Siemens part number 6AV6-644-OAB01-2AXQ
Cheers
Yes, thanks we've already established that.
HMI connected to S7400 plc via profibus DP set to 1.5MB
Plc not showing any errors and hardware diagnostics all clear.
Once again, has anyone had issues with the above screen !!!!
No issues, but never used it with the DP interface, only Ethernet.
Do you need to reboot the panel to get it up´n running again?
Cable length of profibus, noise from other power cables, grounding runed paralell with profibus .. that´s what I´m thinking of if you don´t have a problem with your panel itself.
Hi, I have a MP377 12 inch touch panel . when turn ON its show only white screen . In the RJ45 two lights always ON. I can't communicate, In...
2,794
Hi I have an alarm window on the tempate screen that i wish to toggle the visibility when the alarm indicator is pressed. I have done this...
2,406
I'm still getting used to working with Siemens Step 7 Classic, and WinCC in the Simatic Manager package. I need a trend line on the MP377 HMI, and...
1,847
Should be an easy question. I just can't seem to search the right words... I just got a Siemens CP5711... one goes to the PC via USB cable. The...
2,487
need communications setup for siemens mp377 to talk to a cti 2500 via rs422, anyone done this?
1,551
