zn1102 Member Z Join Date Jan 2006 Location windsor Posts 1 Jan 26, 2006 #1 I have a Siemens OP270 HMI unit running ProTool communicating with a PLC 317 over the MPI port. I was wondering if I can load Step 7 software on the OP270 and be able to go online with the PLC.
10baseT Member 1 Join Date Nov 2005 Location wrexham Posts 271 Jan 26, 2006 #2 No , Sorry , but you can't . The only way that you could achieve what you want is by using a PC670 or other PC based HMI , then you could install S7 .
