Siemens OP7-DP
silva.foxx
Dec 2004
North Wales; always West to England!
519
Hi.
I have an text-based HMI off our "scrapheap challenge" section in our engineering stores. On powering up it goes straight into READY FOR TRANSFER.
I wish to download a ProTool program into it. I am connecting via a USB>Serial adaptor and DB9-DB15 lead. When I attempt to compile and download the program the compiler aborts download due to OP NOT NETWORKED. I've tried manipulating the Peer parameters for the desired PLC connection to no avail. I've tried seleting "not networked" but error on peer not selected. I've done the [Down] +
+ [Esc] to erase flash memory.
The adaptor and lead works between ProTool and an OP17 successfully.
With the OP coming from the free issue of our stores, it looks used though not abused, so may be faulty... I don't know.
Has anyone experienced this?
Thanks in advance - silva.foxx​
I don't have pro-tool on my pc to check the options right now but......
Did you select "serial transfer" in Pro-tool?
Or is it trying to do a network (profibus or MPI) transfer and failing
Jason
ProTool Download Preferences; Serial > Com1 > 9600
Settings for Ports in PC's Device Manager is set to 9600 baud for USB-serial adaptor which, as above, works in connection with an OP17.
Unfortunately I don't have a spare/new OP7 to set in READY FOR TRANSFER to compare. This iffy unit has MPI add. 3 written on the rear.
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
954
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,545
Hi Guys, Hoping we still have some Siemens Old hardware Gurus on here. We are trying to support one of our long time customers. Who have obtained...
942
We have a customer with a very old piece of equipment (circa 1999). That has a OP7 Siemens HMI unit. Their current unit has gone down, and are...
6,289
dear friends, kindly guide me how to download software for op7,op77 if possible give the link.
2,399
