Siemens OP7
PACMAN
Apr 2004
HUY
Hello,
could someone tell me how to force a bit in the PLC from a siemens OP7?
Using screen zone or ... ?
(with protool)
Thank you.
OK, I see what you mean.
In a screen, highligt the F-key you want to use and select the "general" tab.
Use the "Bit in tag" number to pick one bit to represent the F-key.
It seems that the bit will stay on as long as the key is pressed.
Alternatively, you can set up global F-keys (will be active in all screens). You have to add a "System keys" area pointer.
Then in System .. Screen/Keys you can select a bit in the area pointer that will be used globally for the F-key.
NB: Your CAPS-LOCK is stuck.
thank you...
sorry for the CAPS-LOCK but i am using a portable and i need to use the numbers very often so....
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
953
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,543
Hi Guys, Hoping we still have some Siemens Old hardware Gurus on here. We are trying to support one of our long time customers. Who have obtained...
939
We have a customer with a very old piece of equipment (circa 1999). That has a OP7 Siemens HMI unit. Their current unit has gone down, and are...
6,287
dear friends, kindly guide me how to download software for op7,op77 if possible give the link.
2,396
