Hi, I was wondering if someone can help. I have a Siemens TP270 10" Panel where I want to setup a couple of trending charts.
When setting up this, the Data Log storage Path points to a storage card. Am I correct in assuming that I require a Compact flash card?. If so, will any compact flash card do?
I know when setting up Panelviews that AB require you to buy their card type and only recommend a certain amount of memory. Are Siemens the same or can I just buy the latest Compact Flash from a shop? Thanks for the help
