siemens pg and s7 200 communication
mehkocak
Jan 2005
58
I have a siemens pg as you know it has the all ports to communicate with siemens plc but I have a problem when I try to connect to s7 200 (cpu 212) it find the plc in network but I can not do any change, it says check the ports,baud rate and vice versa.
Does anyone have information about which port of pg I should use and connection cable between pg and plc.
thanks
You need an MPI cable and U should use the MPI slot. You can select which the type of comunication in the PG...setting in the control panel.
Rudi
hi
But if I choose cp5611(PPI) with using mpi port it sees the cpu but not download or any other action and I am using the cable ( pins one to one) that I use for s7 300 but when I choose the communication protocol cp5611(MPI) it can not find any cpu with same cable.By the way do you have any information about the connection diagrma of mpi cable.
thanks
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,882
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
220
Hello, I'm trying to figure out, if it's possible to communicate with 3rd party device (robot) over EtherNet/IP. We're trying to prove, that...
4,923
Developing Communication between Energy Meter(Indigo+ Schlumberger) & SIEMENS S7-1200 Hi Members, I am Currently facing a challenge regarding...
1,491
Sir, When i connect my new sensor with plc the hmi show communication error before its working with the old sensor now we have to replace the...
2,652
