Siemens PLC Analog Test Pot
strebej
Sep 2002
Neenah,WI
24
I hope you guy's can help me out with this one:
I'm trying to build a analog test/calabrator meter. I will be assembling this portable test case that I can use in the field. I'm trying to figure out how I can test Siemens Analog IN/OUT PLC moduals using the output channel to feed into the input channel on the same modual. I then would like to be able to adjust/trim the signal and have a readout in the portable case. If you refer to the attached drawing you will see I have a start but I need your help...
My question is this:
1. Will this current circuit work?
2. I would like to use two (2) ea. Potentiometers one being the main adjust and the scecond being the trim adjust. How would I connect the second Pot?.
3.What should the OHM ratings for the Pots be?. I was thinking of using 5k for main and 1k for trim.
4.Where should the 4-20mA panel meter tie into this circuit at?
Am I the only one who cannot see your attached file?
As for your questions, I have done something similar using GE genius bus analogue blocks and a series six PLC, where I fed the analogue out back into the analogue input. I used the PLC to adjust the output current/voltage. This worked fine for me, I have not tried it using Siemens (yet).
When I can see your drawing I might be able to give a more specific answer
Paul
Ok while I was posting you submitted your other post, so ignore this one
Hello, new to the forum, been here over the years on and off, but now I am more involved at work so I run into more difficult problems.... Maybe...
4,005
Hi all, Does any body have some literature on how to scale the analog input signals e.g level tank control using a pressure...
6,252
Hi..all..I am a newbie in this field..trying hard to acquire some good knowledge in this field. While studying about the analog input modules in...
5,444
5,778
Dear sir, we are getting fluctuated output from plc even though batching controller is showing constant value after batching completion...
3,187
