analog output fluctuation from siemens plc
balotagi
Mar 2008
koppal
Dear sir,
we are getting fluctuated output from plc even though batching controller is showing constant value after batching completion. we are using fc105 for scaling process. Can anybody suggest how to avoid the fluctuation.
Regards,
Balotagi
Hello balotagi;
I do hope this is a typo, and that you are using FC106 ("UNSCALE") to setup your analog output. FC105 ("SCALE") takes an analog input value (from PIWxxx) and transfers it as a scaled REAL value for your program. FC106 takes a REAL value and turns it into a numerical value adequate for a PQWxxx channel on your AO module.
If this was a typo and the output value is not stable, I have often found that it is a question of wiring and grounding of the AO module. Refer to the correct manual for your PLC family (I presume it is a S7-300 or S7-400, because of your mention of FC105).
Hope this helps,
Daniel Chartier
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
319
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
109
251
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
544
