Siemens PLC and double network
teo87mat
Sep 2023
ITALY
Hello All,
IÂ’m starting a new project where the plc is connected throught LAN with external software which write some data on PLC db, obviously PLC is also connected with I/O devices and wincc.
The goal is to keep i/o device(and maybe also scada pc) outside of the main network while the PLC should be connected with that external software. The solution is to use PLC with 2 or more PN? There are other solutions?
Thanks in advance
Best Reagards
If you have something like a 1515-2, with two ethernet interfaces, this is easy. 1st interface goes to IO and HMI, 2nd interface goes to upper level network, to do whatever other thing you need.
If your PLC only has 1 interface, you can add a CP card to add another ethernet interface, or you could use something like an S615 to route to the other network (with firewall rules, etc, possibly NAT depending on the situation).
184
114
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
378
