Siemens PLC memory vs Allen Bradley PLC memory
JensV
Oct 2017
Halle
Hello,
I have to replace a Siemens (S7-1500F) PLC by a PLC from Allen Bradley (compactlogix 5370), but because of the different ways of programming I don't really know how to compare the memories. The memory of the Siemens PLC is divided into memory for programming and memory for data. And the Allen Bradley PLC has standard memory and safety memory.
So can someone tell how I can compare these PLC's so they have a similar amount of memory.
I think you compare the Load memory on the S7 side to the memory on the Logix side. They both store the same info: tag data, tag names, HW settings. They would at least be the same order of magnitude, but I don't know what the comparison factor should be, whether you need to double one of them or something like that.
Don't worry about the Work memory from S7, whether code or data. I don't think there is anything equivalent on the Logix side.
Dear all, In the attachment this is a complete recipie management in Siemens S7 PLC. The recipie management using the load memory (PLC memory...
1,784
As I always say I have been using Allen Bradley PLC. Now I have tried to learn about Siemens PLC.What I am able to understand is Siemens PLC...
6,552
Hi, I successfully connected to a S7-1200 and can send receive data between the computer and the PLC by using the send/receive blocks. Now, I...
4,972
In the company I worked for before I worked here, there was a standardisation on a CPU 315-2DP. (carpet factory) Now I work for a...
5,380
Hi all, Correct me if I'm wrong but if I hold down the MRES switch on a Siemens 300 series PLC and wait until the amber light stops flashing...
21,833
