Siemens Profibus To Micromaster 440
We have Siemens Micromaster440 6SE6440-2UD33-0EA1 With firmware 2.08 installed in our Textile machine. Before few weeks ago, our micromaster 440 was out of order and we installed new micromaster440 6SE6440-2UD33-0EA1 with firmware 2.11 inverter to machine. we have to take all paramters from our defective micromaster. when we try to transfer our paramters to new inverter, Message appear that "firmware version not match" we change firmware setting from drive monitor and download paramters to new drive. It was sussfully downloaded. when we start tha machine with the speed of 5meter, But the motor speed goes to 9 while all other motors run in 5rpm. Our PLC communication with inverter based on analog refrence of 0-10V.
We are in big trouble to solve this problem, if we decrease p2000 then speed match with our chain motors but when we increase the speed then our dancers and other motors speed not match.
Please send me information to solve this problem.
1. Yes, speed setpoint is an analog input which is connected directly to PLC analog output.
2. Yes, dancer give analog input directily to analog input module.
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,975
Hi I've a micromaster 420 motor drive, with profibus connection to PLC. I have a AWL function wich read the status word and send the command word...
3,594
AB controllogix, Molex profibus SST card and Siemens MicroMaster 440 & Sinamics G150 Hi, I have project which use AB Controllogix as PLC and...
4,962
Hi I have some doubts about profibus communication between a plc siemens (314C 2DP) and the inverter SIEMENS MICROMASTER 420 1)I have read that...
4,540
Evening all. Got a bit of a problem here, process was running fine, 440 fails, new one installed, process not running fine anymore! I've never...
4,372
