Siemens - Profinet diagnostic
Weo
Feb 2006
Sweden
82
Hi All,
I´m setting up a 300 system with some profinet nodes.
I have experience of how to read status of profibus slaves (FC125) but not profinet, first time user of profinet.
I just want simple diagnostic, if a module error occurs on node or the node is not accessible I want for example a bit to settled.
The function "Report system Error" is not really what I´m looking for, I understood that you with FB126 can get this functionality.
Also seen something about SFC51, someone with experiences?
Once again, I just want very simple diagnostic and prefer not to do too much programming in interrupt OB's, for profibus I liked FC125, Just call it and it saved status of ALL slaves to one DB.
What´s your expereinces and recommendations of profinet diagnostic?
I had a look at this siemens project/library (FB126) and did some testing. Anyway I cannot understand the data in the instance DB (DB126).
When I have a fault on a node (BF or SF) I cannot see any data in DB126 changing.
FB126 is called cyclically from OB1, just as in the Siemens example.
Anyone here that used FB126 and know how it works?
161
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
392
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
325
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,896
Hi all, I am a AB guy tying to figure out Siemens' system integration. I have been asked by my company to install new IO for Siemens 315 CPU...
805
